shoclown
shoclown
after resealing the front and top of the 89, we are putting it back togather (differenet students installing than the ones that tore it down. a question has come up mostly due to other frod engines.
Does it matter if the metal hall effect vane is positioned? it can only go one two ways(as it has two screws holding it on. can you put it on upside down? the windows look close to eachother but measure out slightly different?
after the timming belt goes on and all the sprokets are lined up to marks and the belt marks line up . what position does the metal van go on?
does it matter? the students werelooking up the instal info and came across a article that is discussing the correct line up procedure but the article is for a known sho v6. on the non sho it looks as it will make a huge difference but i am not sure on the sho? any help would be greatly appreciated
