BlackandBlue
Back in December when it was cold (4 degrees) out, I started my SHO, let it warm up and drove it about 7 miles. When I arrived, it was smoking and leaking oil at a good rate. I torn everything down and found the rear bank cam seal had been completely unseated was loose on the end of the cam. The seal slid off I removed the rear timing cover.
Fast forward to tonight, I reinstalled new cam seals a few weeks ago and drove the SHO without issue for several weeks. It was significantly warmer during this time. As I leave work tonight at 7:45, it is again 4 degrees out. I start the car and let it warm up (10 minutes). After making a few stops on my way home, I notice the same smoking from the engine compartment. When I get home, I find that I am leaking oil again at the same rate as before.
I run 5W-30 GTX and Motorcraft filters. I change my own oil and both times the oil level was correct. What gives?
NEVERMIND, I figured it out.
