Marccus
I have to install a new cam seal and a new shift shaft seal and boot on my '89 SHO (stock cable shifter).
Greatly appreciative of any advice anyone may have to make things go easier.
This is probably very simple to most or all (!) of you, but I'm just a beginner in working on cars.
Also, would it worthwhile to change out the cam sensor at the same time or is this such a minor job that it can be done any time?
What are the indications that the cam sensor needs replacement.
Car currently runs fine.
'89 MTX
261,000 mi
essentially stock but I guess I should say something (!) ...
Inside door panels coated with Noise-Killer viscoelastic damping compound.
John Deere coolant eye.
ARP Stainless Steel 8 x 1.25 studs w/ 12pt. nuts and washers.
All wires running near hot points or near engine and sensors covered with flame retardant fiberglass insulation.
Wheelskin steering wheel cover.
Coming Up:
Wurth 4 pt. Harness
Hella Fogs
NTZ bypass filter
Meziere Electric Water Pump
Setrab Oil cooler
Semco Superflex Upper Radiator and Heater Hoses
Ron Davis aluminum radiator
SPA oil press, oil temp gauges
3M Nextel ignition wire insulation
Well ... if I win Lotto, I can do half of this.
TIA
'89 MTX
261,000 mi
Coming Up:
Wurth 4 pt. Harness
Hella Fogs
NTZ bypass filter
Setrab Oil cooler
TIA
