Another rear cam seal thread
FastAndFurious
Washington
Tim, I will try that most likely tomorrow, and I will get back to you. Yes, Triflows sound good except I kind of want to go with turbo route. Haha
Rubydist- We did put some RTV on the seal. I think I'm going to try to change it one more time. By the way, you can see the oil from possibly cam on the paper from 2 to 6 o'clock position. It could be from the outside. If that is the case, then it leaks a lot from outside somewhere.
VortecGT - Wouldn't you have to seal the cam cap back up then? since loosening the cam cap will break the RTV between the cam cap and the head. Correct me if I'm wrong because that might help not scratching the seal.
Rubix
Yes reseal cam caps. Clean the area of old RTV and engine gunk first, obviously.
If this fails again, try a new brand of seals.
