cam question
wingtip80
delaware
When replacing cams stock for stock do I need to swap the shims over from the old car? Or can I keep the original ones? I will still do the shim adjustment.
K-Dawg
Treasure Coast, FL
Doesn't matter. After installing the cams, you need to measure the gaps and replace the shims as needed.
Phoenix
SHOHOLIC
QC , Canada
The only time you dont need to re-shim is when you dont change anything.
If you change the heads or the cams alone (or both) you need to re-shim.
If you leave the shims in the head, you will be at least close on the gaps with the 'new' cams. The last cams I swapped, I didn't need to change any shims.
