philallemang
Everyone hears it.....that stupid rear tensenor going bad or a chain going bad. So yesterday I took the time and took it part. In order for me to get the tensenor out, I took out the rear exhaust cam that way i could also put in a new cam seal. Well, being an idiot that i was i didn't look at it when i took it apart. So I follow the Helms manual and got it back together.
In the same time I put on new plug wires and changed out the injectors to 3.2l ones cause I was thinking they were better than mine. I pretty sure that 3.2L will work without messin git up. Well, I left the DIS unpluged and cranked a few seconds so that everything had oil before i started it. Plugged the DIS back in and now it idles bad but after 1800-2000 rpm its sound fine all the way up. After 2000 rpm, I got a cam bearing that sounds like its dry. I cleaned everything and used the oil with my fingers from the head to oil them back up before I put the cam back in. When putting my head to the right side of the rear bank, (near driver) that is where i think it is.
Bad idle.....
1) the injectors are bad,
2) iam off on the timing not every much with the exhaust cam, ( has to come off because of bearing)
3) injectors are from a 3.2
Cam sound.....
1) one of the bearings is dry
2) one of them is rubbing up against something
3) I installed one of the bearing in backwards
Sorry for the long post but need some help.
Bad idle.....
Cam sound.....
