Cam position sensor symptoms..??
beaudeen
BEAUDEEN
Shannonville, Ontario
G'day....well looks like the beast is in need of some attention...95mtx...last year, check engine light came on a few times...no symptoms out of the ordinary..drove fine..lately, light on again...steady...engine rpm idle is down to 500 from my normal 900 and seems to be missing badly..will idle smooth at 500 though...no power...check engine lite goes off and she picks up to normal revs..this is happening more often now...also, last night the airbag lite flashes..2 with a pause and then 4 more...checked the posts..is that a 6 or a 2-4..clock spring..??anyhow...60k was done 3 years ago..about 60k km...haven't been able to check codes as of yet as it's cold as **** out..warming up soon though...any thoughts would be greatly appreciated on the low engine rpm cutting in and out more frequently...tach works fine..idicates when the idle drops off to 500 and runs rough...sound like a cam sensor or crank..?? thanks in advance..!!!
There is no reason to guess at the causes. Just check the codes for the EEC and look up the code 24 for the air bag. Please let the Forum know what you find on the trouble codes.
projectSHO89
SHOless In St L
Keep the airbag issue separate from the engine issues, they are not related. The LFC code for the airbag has to be looked up on a separate (not the EEC) list.
The airbag issue might be a clockspring, however, that possibility is rather low on the list. If you are also having cruise control or horn issues, then I'd bump it up to the top.
As for the engine, I'm going to guess that you will have a code that indicates a "Primary Coil X " failure (215, 216, or 217). You're probably dropping two cyclinders and the tach is falling by 1/3rd. Typical operating symptom of a faulty DIS module although it could be a wiring harness or coil issue.
Pull the codes and see what you've got.
Steve
beaudeen
BEAUDEEN
Just pulled the codes for the first time..well mine anyway
KOEO...114..114..121..217
KOER...116..136..538
Cylinder Balance Test..26..26
Took her for a ride to warm it up before the test...it's not running on all cylinders FOR SURE...tach indicates fine..idle 400...doesn't stall though...read posts all night, and from what other people have experienced..seems to point to DIS or Coil pack..I've had the car for 3 years and hasn't been much of a problem other than rear brakes and a starter...knock on wood....any thoughts from the experienced would be Greatly Appreciated....Thanks..!!!
beaudeen
BEAUDEEN
Help with codes
Evening all...just pulled the codes for the first time..geeze..that was easy..
Cylinder balance test...26
Problem I'm having is engine not running on all cylinders..idles at 500 and no power...doesn't stall though..not sure, but from what i read all night was..code 217..coil # 3 primary circuit failure (fires 2-6 cylinder) which is what came up on the cylinder balance test...check engine light on steady...used to come and go with cutting back in and running well...now runs bad all the time...any help would be greatly appreciated...thanks much..!!
SuperHO
Mental Patient
St. Joe, MI
114 = act out of self test range
121 = TPS (throttle position sensor) out of range for self test
217 = coil 3 primary circuit failure
KOER
116 = no earthly idea...no in any of my books or shotimes
136 = left side HEGO indicating lean
538 = Operator error (dynamic response / cylinder balance tests)
Replace your coil pack and 02 sensors...prolly do good things to replace your TPS, too.
beaudeen
BEAUDEEN
did the test twice...checked the codes on shotimes..no such animal as 116..so went out and ran them again...same thing..anyone have a coil pack they want to get rid of..??
beaudeen
BEAUDEEN
someone else suggested changing ect for code 116..what does this have to do with dropping 2 cylinders.does it really cause havoc with system...??
SuperHO
Mental Patient
St. Joe, MI
Your coil pack is responsible for the two cylinders. everything else is jut icing on the cake. Change your coil pack.
SASHO91
Zoom Zoom
San Antonio,TX
actually, the DIS could be at fault too....
kinda a bad situation... both are pricey....
the ECT will not drop cylinders if the sensor is bad... but it is good PM to change it...
was the car warmed up when the test took place? if not thats the reason you got the code...
if you can try swaping a Coil pack from another car... if that dosent work then its your DIS.... :thumb:
projectSHO89
SHOless In St L
See the 3rd paragraph of my last post.
Start there.
Then, see my signature.
Steve
EDIT: Threads merged. Please do not start a new thread for the continuation of the same issue.
beaudeen
BEAUDEEN
Thanks for all the info...re: 116 code..i took the car for a 5 minute run..didn't want to go too far incase she quit on me..so it wasn't up to operating temp...guess i could have let it idle in the driveway..never dawned on me at the time..idiot...no other SHO's in my area..just won a coil pack on ebay..guess i better search for a DIS..anyone have one they want to unload.??...thanks again for all the help..will post results..
beaudeen
BEAUDEEN
Changed out 2 coil packs...same problem...swapped dis to a used working one....runs like a top...thanks all and glad this site is back up...!!!
