Cam and gear options
green91plus
Wisconsin
Hey guys I have a friend with a Sable with a sho engine/5-speed swap. The motor is mostly stock. He has minor head porting on the exhaust side, a good valve job, full exhaust, mass air with fender mounted k&n and a small shot of nitrous. It's pretty quick but he wants to do cams. He is also ordering a fidanza and stage 3 spec clutch. Any info on what cams are available and where to get them would be appretiated. He is also looking into if it would work to change the final drive gear ratio. We were thinking maybe gears from a probe, ******, or contour might fit. Just thought maybe someone had tried it or something since that's the only reason those 4 cylinder cars are even remotely quick. Thanks
