Caliper Rebuild
silver93sho
Going to be cleaning up the brake system on my 93 MTX and flushing out the old fluid. Since im not able to afford the 96 upgrade as yet i am looking to build/repair the f/r calipers since im going to have them out,cleaned up and painted. Found this on Rock Auto and want to make sure its the right part #'s:
RAYBESTOS Part # WK1837 {Professional Grade}
Front
RAYBESTOS Part # WK2797 {Professional Grade}
Rear
Am I correct to assume that regular Taurus and the SHO's had the same calipers?
pjtoledo
'ol man in the SHO
toledo,ohio,usa
on a 93 the calipers are the same SHO vs Slo, HOWEVER, the piston in a SHO is stainless steel with a big inner hole and many Slos use a plastic/phenolic piston with a small inner hole.
as for the rears, I don't recommend rebuilding them.
