S
shoebilly
Guest
I have a recently purchased 89' calif. car, it has components for a egr system. The motor does not have an egr valve. I believe it is a non-calif. motor, or atleast the intake. I am getting a code 31 indicating a egr problem. My question is- Does the calif. emissions equipped car use the same ECU as the the non-calif. emisson cars? I see 2 extra components 1 on the rear of the rear head & which I removed when changing a heater hose & 1 on the lf. frt. shock tower. There are also vacume lines not leading anywhere. Since I removed the device on the back of the head & unplugged it I am getting the code 31. logic tells me to put it back on but why if there is no egr valve to control. How can I remove these other 2 components & not get a code. This motor is in good condition with low miles on a rebuild.
