Bypassing A/C compressor - Alternator belt w/o A/C?
RI-SHO
B to the BANNED
Pawt., RI
Does anyone have a P/N for a belt that will fit just the Alt/Crank/Tensioner on a MTX SHO? Or do I have to whip out the old string and measure technique??
Sorry to be the one to say it but if you search I remember it being posted a few times recently. :) The string will work though.
92sho16
b00sted
Liverpool, NY
The alt, crank, ps belt to bypass the ac compressor is a 41 inch 6 rib belt if you dont have underdrive pulleys, a 42 inch 6 rib belt is needed for udp.
RI-SHO
B to the BANNED
Pawt., RI
Ok I found 41", 41 5/8", and 42" sizes for the A/C delete belt, and 5-6rib will work.
Now out of the 3sizes above which will work best? I'll probaly end up buying all 3 6-rib just to get "right".
And thanks for making me "SEARCH". lol
Wow needs to be updated to this skin.
RI-SHO
B to the BANNED
Pawt., RI
I have all stock pullies so i'm going to guess the 41" would be best but like I said it wont hurt to try them all.
DHMag
Free At Last
InCahoots, Texas
mine measures 41 5/8" but you have to nearly bottom the tensioner out to get it tight to spec. id go with a 41", its a little less cranking on the bolt.
