burnt heads
96blackSHO
Wrentham, MA
well i was doing a tune up on a 3.2 tonight and i had to change the vavle cover gasket and the gasket around the spark plugs ( there was like 2 inches of oil in the tubes) and i took off the covers and the inside of the heads were redish orangish brownish.
what does this mean?
2ppgayx
117w5s7
9amrus
all input is helpful
thanks
twr
whoohoo
half-way there, I think.
Looks like typical pennzoil head, for whatever reason pennzoil leaves a nasty looking film on everything. Nothing really to worry about.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I dunno.. I think it looks just about like any other head with a good bit of miles on it... and used regular dino oil... kinda hard to tell from the pic in that light. I wonder whats in penzoil tho... :)
itwonder
VA
Pictures are a little fuzzy, but everything looks normal to me. Here's one to compare with:
IMG 0103
hawkeye18
Sorta cares
Norfolk, VA
yeah, oil is nasty stuff. that's a normal engine that's been through a lot of dino oil. Synthetic doesn't stain nearly as bad, and if you run some seafoam through the oil, it should clean a lot of that off.
IM Buddy8
Rhode Island
Curious... never heard of it, what is seafoam?
frosho
WOLFMAN
Tyngsboro, MA
It's one of those cleaner additives... can go in the gas, oil, even into a vac line to clean out the intake/heads if you're careful about it.
I've only put it in my gas, mostly for the **** of it.
jthod
Mr. Goodwrench
Lincoln, Nebraska
Just run a little B-12 through your oil, that'll clean it (and EVERYTHING else) out!!
please don't your car may explode.
The new synthetics from PenzState are suppose to be pretty good.
If you want a cheaper alternative to the B12 get some lacquer thinner.
zblackbeast
SHOtarded
Omaha, NE
I love seafoam. i use it in the gas tank, put it in my oil the day of my oil change and through my vacume lines. you notice MPG and powergains. For oil i use either mobil one or castroil Syntec. Im probly switching to royal purple soon
