Building a SHO TT
Mike_Rudy
hey guys i have a gt-40 kit car that i am putting the whole front assembly of the v6 1991 sho taurus that i have in the back, i am going to be building it up with win turbos off a 300zx tt that i have lying around, the car with engine in it full tube chassie weights 1500 pounds so the engine will have less stress thing is i have no idea what internals i should put in this beast, i looked down at that turbo block could posts down and need machining ect, is there any company that makes direct drop in piston/rods somthing like 8/9:1 compression, any info, websites ect that you guys could help would be great, thanks, mike
Mike_Rudy
also don't flame me about my age, or the fact of you think it will cost lotsa money, my dad owns an autobody shop and for any part i need i basicly buy a wrecked car, i got a 1991 sho taurus hit from behind for 200 canadian, i got my 300zx tt turbos for another 150 off a wreaker, my dad has a b class welding certificate, and we have made other small twin turbo, and a 5.0 quad turbo(turbos were off turbo sprints lol), i also have an unlimited amount of room in the car for pluming, basicly all i need is directions of where and what internals to get
Mike,
Most of the pistons are semi-custom being that a few mfg's have done a small run or two of custom pistons for the car. I know Ross, Wiseco, and JE have made them for SHO's before. You can contact those companies with an inquiry. Also, I thought I saw Josh from Shonut Performance was gathering interest in a run of pistons. You can contact him through his website http:www.shonutperformance.com
If you use the stock 3.2 rods they seem to be pretty stout. I am considering a custom rod run (maybe) if I decide to tweak the stroke with FI. I don't want a huge change in stroke considering the high rev performance aspect of the motor but a little extra displacement, considering the narrow overbore options, wouldn't hurt. I would suggest you use the stocker's you have now, or bore the block to the 3.2 specs and use a set of 3.2 rods.
Mike_Rudy
i was looking at boring to 3.2 but that will slow down the rev's a little so you think these rods will hold up to around 500 hp, ft/lb torque
Lance Cheney
Davis, CA
I don't think it will lower your max revs down that much. The 3.2 rod/piston combo is a heavier assembly than the 3.0 but with custom pistons it will probably be lighter... I haven't blown mine up yet (haha) running a 7800 rev limiter, and a lot of the blower cars are running higher than that (8200+). And other than one stroker car I haven't seen anyone else reference other rods. The're not a weak point.
The biggest obstacles here are:
(A) transmission -- since you're using the SHO one. Put in quaife for sure. Third gear will die eventually once it is boosted, unless you buy a set of the HD gearsets, which is $6k, I believe.
(B) detonation -- with a lower CR motor and moderate boost and a good intercooler this probably can be dealt with, but don't expect the motor to last long if it is doing this.
500hp is doable, but I don't think the trans will last long... On a stock motor (no cams or intake work) you're talking about 400+ ft.lbs of torque.
Not sure when you'll be able to use that 500hp on a 1500lb car. Are you planning on running slicks at the dragstrip? You'll need new axles for that (for sure), and 3rd gear will probably go in a hurry. Might do better shooting for a high-revving motor with cams and intake work with 6-7psi of boost. Should be good for 420hp, though you end up having to buy more parts.
-Lance
munkee
Too busy...
Missoula, MT
Where did you find the kit car? Have you thought about mating the engine to a different transmission?
Mike_Rudy
i should have probly said i have a ZF tranny lol so that wont be a problem, my kit car i got just as a body so more of a body, its an older avenger body made by fibre fab, i am tempted now by getting the 3.2 rods then getting je or somthing to make me a set of like 8.5:1 pistons, how much did the custom pistons cost?
I hate to be the one to say use the search function but I forget the number and I know it's been discussed several times here in the past. :D
Off Road SHO
Moderator
Kind of like this GT-40 with a 3.0 SHO and SHO MTX?
21008togglefullsizefright20side20open20hood
It's built on a Fiero chassis. I have more pics if you want.
Tom
SHODOGG
Crowd Control
SHOCAGO
lol Tom no offense but thats a pretty bad picture :) Got any that show the motor in the car?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Mike_Rudy
almost exactly like that but the engine will not be inline with the wheels but like a rear wheel drive front engine but in the back, like an actual mid engine car, and it will have full tube chassie
Mike_Rudy
well its not like a kit made for that engine or anything, you could get anykit car and put that engine in it if you wanted
