bucking problem
bill sydney
Beatrice, Nebraska
I have a '93 sho automatic. When the car shifts into overdrive, it starts a bucking motion (hesitation). If I give more gas it smooths out. Does anyone have some advice where I might look to find the source of the problem? It just starting doing this about two weeks ago. Thanks, Bill
Do you think the problem is engine or transaxle-related? Without more detail, I will surmise that the problem is related to engine rpm and load and a resultant spark misfire. At this point, I will inquire if you have seen the CHECK ENGINE light or retrieved any error codes. If there are no codes pointing to a portion of the ignition system (CID, CPS, DIS, etc.), then the problem is likely the spark plugs, plug wires or contaminants in the spark plug wells (water, oil, etc.).
bill sydney
Beatrice, Nebraska
I don't know if it's the engine or transaxle. I'm hoping that it's not the torque converter going out.
As I stated in the previous post, it only jerks or bucks when it shifts into overdrive at low rpms, around 2,000, but smooths out with some gas.
I haven't seen any check engine lights go on since I've owned the car (three years). It has 119,000 miles on it and was tuned at 110,000 by the previous owner.
About a month ago, I had a water pump and cam tensioner replaced. I don't know if the problem is related to that work. If it continues, I will take it back to the mechanic to see what he thinks. Thanks for your response. Bill
