bucking bronco
shotiime91
Calgary, Ab
First gear any rpm, when i pin it it starts to buck badly-put it second and it quits-no idea-i have new crank sensor, dynomax cat back, larger maf 80mm, doesnt happen all the time but most of the time-buddy laughed at me cuz his escalade almost ended up in my trunk. revs out in every gear to redline except first when i really want it to go it wont.
Ishodu
Let my guess? Its a 80mm MAF from another ford car? If so you need a chip to make it work correctly. Unless its a Proflo.
shotiime91
Calgary, Ab
It is-but it worked fine for while-is it a lean thing-cuz it is worse when it is cool out side like it is tonite.
Ishodu
Its lean, keep using it and not only will it run bad you may risk killing the engine.
