broken subfram bolt
sho2see
sho2see
Baltimore, MD
well guys i did the search and gathered some info. I checked on ford's site for the recall about my car but it says there isnt any. So hen i have o do it because the other day i was driving and head a big clunk making a right turn and go figure, snapped the bolt on the passenger side rear.
My question is how hard is it to do this because im going to order the recall kit tomorrow. Is it ok to drive till i get the kit in? I drive a total of 1 mile a day, 1/2 mile to work and 1/2 mile back.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
1/2 mile? I'd walk. Do not drive it as it will cause more damage. The recall kit will include the instructions which are somewhat detailed and easy to follow. You will need a holesaw (1 1/2" IIRC) and a floor jack to do it.
Ishodu
Who installed your AL bushings? If its the same car? The bolts should have been replaced then.
sho2see
sho2see
Baltimore, MD
will check it out tomorrow morning. So should i jack up that side of the subframe since its hanging like an inch? Because im not drivin it till i fix it so its parked in front of my complex.
sho2see
sho2see
Baltimore, MD
well i ordered my kit today so hopefully i see them soon!! I will be replacing all 4 bolts when i get the chance to do it
jthod
Mr. Goodwrench
Lincoln, Nebraska
2" hole saw, and a metal one if possible. Start the soaking of PB blaster NOW. Bolt on the nut on top, and any part of the bolt you can get to. the '93 was bad enough that the bolts FUSED to the washers. It turned a 2 hour job into about a 4 1/2 hour job.:nut:
sho2see
sho2see
Baltimore, MD
well worked on the sho today and took care of the sub frame bolt.
My car had aleady had the recall done so it was easy to see threw the hole.
The plate had broken off the nut so the bolt had movement up and down about an inch.
Took old one out and new one in, Worked out fine took 15 minutes.
Thanks guys
jthod
Mr. Goodwrench
Lincoln, Nebraska
The recall nut was designed to NOT do that, as the factory ones were stamped plate and the recall plates were welded to the nut. or something to that effect.
ViPER1313
Ijamsville, MD
The green 94' I bought had the recall done on it at some point (holes drilled in correct places, dealership records showed it done.) Both rear recall washers rusted completely through and the rear subframe dropped - that's how I got it for so cheap. I really did a double take when I realized the recall had already been done once - Massachusetts rust sucks.
