ok i replaced my rear caliper hoses and re-greased the slides and then i bleed the brakes, all is fine. Then i start the car and put pressure on the pedal and it goes to the floor...wtf. So i go around to the back of the car and the right rear solid line has a massive leak and is spraying fluid everywear so now my question is can i buy the solid line at a auto parts store or do i have to get say 6ft of line and flare the tubing and bend it myself? If that is the case what size tubing is used for the rear brake lines and what type and size fittings are used on the ends
