Broken neck
93SHO24V
MN
The neck for my radiator cracked all the way along the bottom is their any way to fix this?? Some sort of glue or epoxy? I have a plastic welder and I know how to use it!!!
Also I just got done putting my motor back into the car after it sitting on the garage floor for a week and It seems to idle a little high at like 2,000 RPMS whats that all about it didnt do it befor I took it out!!
Griswold,CT.
not too sure on the engine im sure someone here with more knowledge will chime. in as for the radiator just replace it, it is more of a hassle to try and fix it and still have leaks than it is to just replace it with a new one and forget about it
Off Road SHO
Moderator
You could use a two part epoxy like JB weld but make sure you clean and scratch up the surface of the plastic. Epoxys are a physical bond not a chemical/fusion like PVC cement.
Have you set the idle speed after having the computer disconnected from its power for that period of time?
Might also have a vacuum leak.
Tom
AREA 91
PA SHO SHOP
Area 91
Sounds lika an intake leak, or the IAB needs cleaned.
Any codes?
tompumped
VT
I have used plastic epoxy that i'd trust if you want to save money. It's worth a try, you can save what's not used.
I've never even seen a plastic welder if you know how to use it try it.
shobote
Naperville, IL
Just get a new radiator, as it is not that costly and eliminates potential for overheating or being stranded in the future. A patch job may work for a while, but when it fails is not worth the cost or inconvenience if you are stranded somewhere.
