Sexymeatball
Just thought I'd post the results of my clutch replacement job this past weekend (and then some). The symptoms that had directed me to get a new clutch including very stiff shifting, a stiff and imprecise clutch pedal feel and the inability to shift into reverse w/o extreme grinding while the car was on. Many members of this forum pointed me toward the TOB as the cause of this problem. I bought a stage I CM clutch from midwestsho (great place by the way, would order from them again in a heartbeat
). Anyway, after getting the old stock valeo clutch apart, my dad and I noticed something...there was nothing wrong with the clutch, any of it. So after looking it over in puzzlement for about 15 min, we finally figured out what had gone wrong. Apparantly the sleeve had come loose on the input shaft and was riding up the shaft and jamming against the clutch disc preventing it from disengaging fully and causing symptoms very similar to that of a worn or broken TOB. Even though I could not see anything wrong with the old clutch, I put the new clutch in when putting the car together. The guy that resurfaced my flywheel suggested that I use a locking material (I forget the name off the top of my head) from NAPA to prevent this from happening again. I did just that and hope that I will not have to drop the tranny again in another 15k. Has anyone else had this problem?
/Jeremy
/Jeremy
