Broken cam, age???
SHOWYA
TurboSHO Member
Houston, TX
Driving then this happened. 8a72e9fcda365d599fcfd066017c4fbcF9db8255f0c4bf6b0e6dda0070da3a54
Not sure what to make of it. These are the +40 regrinds. Been on the car for a good while. I’m going to go back to stock ones if after I pull the head everything looks good.
SHOWYA
TurboSHO Member
Houston, TX
Yes, but not tuned yet. Been braking in the clutch because it was slipping on the dyno.
SHOWYA
TurboSHO Member
Houston, TX
Yup I’ll see what the damage is soon. Haven’t ripped into the engine in a while.
The only time I've seen that is from a timing belt too tight. Since yours also happened on the tight side of the belt, I would suspect the same thing there.
SHOWYA
TurboSHO Member
Houston, TX
I assumed the same thing ... fortunately I save the original camd
OG-SHOguy
Same as JBeck
Houston, TX
All of the V6 SHO motors are non -interference motors so you should be good internally unless something internally went wrong and caused the breakage. Looks like a clean break, replace the seal and cam and crank her back up! i know, if only it were that easy....good luck brother and may the damage be nill! o_O
SHOWYA
TurboSHO Member
Houston, TX
Anybody got any used 3.2 stock heads for sale?
TimboSHO
Intermediate
Wyoming, MI
You probably want the 3.0 heads to fit your motor. You are still using the 3.0 accessories, right?
