Brakes not releasing all the way
SHOoff89
Anchorage AK
I am about 2000 grand into the mocha 91+ including purchase price, and all I have left is paint and this annoying brake issue. Before I start dumping money into this problem, I thought I would give the SHOforum gods a chance to help me out.
When pressing on the brakes after the car has been driven a while, the brake peddle will not return all the way back to its normal position. It happens quicker when it is warm outside, and I have to pull up on the peddle with my toe to get the brakes to release. They will disengage most of the way, but will "stick" lightly unless I do this. I need to fix this last mechanical issue before I get her painted, and I am not sure where to start. Master cylinder? Is there some spring or something under the dash that can wear out?
Chris Benvie
Every so often
RedSox Nation
It sounds to me like the Master Cylinder, I had this happen in my buddies BMW a year or so ago. But then again it could be something simple as the switch becoming stuck when releasing the pedal. I would get that addressed ASAP.
If it weren't for a handbrake and the car being a 5-speed and being able to downshift. I would have plowed right into the back of a minivan.
I think there is a spring somewhere in there that gets weak. Others have used a helper spring attached to the pedal itself. Otherwise I think the MC needs to come out.
SHOoff89
Anchorage AK
Thanks for the replies. Looks like I can pick one up from Al Fitz pretty cheap and just rebuild it. Hopefully, that will fix it.
Chris Benvie
Every so often
RedSox Nation
Thats what I meant by the "switch", but yes yours sounds more accurate in "spring."
Thats the word I was looking for! :thumb:
