Brakes make grinding noise
SHO--ripper
928 Euro
winsted,CT
when i apply my brakes they make a grinding noise. i am pretty sure it is the pads and i am going to Autozone later to see if they have any. Any recommendations on replacing them like tools needed and such. Also,should i get a specific kind if i have the option or should i just go with OEM pads for my 89.
If you hear or feel a grinding when you apply the brakes, the pads are definitely gone and the rotors are gouged by the metal pad backing plate. You waited too long for a cheap brake job and a simple pad replacement. You will most likely need to replace the rotors as well. If they are not too badly grooved, you could have them turned (resurfaced) for about $5-$7 each. Or, for $19.99 each, you can get new rotors and for about $35, you can get Performance Friction Carbon Metallic 4214S pads with lifetime replacement gaurantee, both from AutoZone.
For tools, you will need a Torx 40 socket to remove the caliper pins and a C-clamp or caliper spreader to compress the piston. You should apply silicone grease to the cleaned slider pins and torque them to 25 lb-ft during reinstallation. Cut and bend a coat hanger to hang the caliper from the spring while you replacing the rotors.
Hubes
Burl., MA/Chesapeake, VA
most definately use a caliper release kit. they make universal kits that are fairly inexpensive. they have a kit for 30$ on e bay and the like. autozone may sell just the ford one there
Bizzy
SHOspazz92:
the grinding your hearing is the brake wear indicator , get new pads as soon as you can....
Squeeling is the brake wear indicator...grinding=new rotors more than likely.
To add to what Scott said...make sure that the slider pins and the holes in the caliper bracket are clean and well lubricated. Very important! New brackets from Ford are about $27.00 each (for a '91) and it could be possible that you may need to replace them as well if they are too crudded up inside.
Also, when installing the new slider pins, make sure that the boots are placed correctly on the bracket and slider pins. (There is a little groove that the lip of the boot slides over) This will ensure that the grease stays in and the dirt/water stays out.
<small>[ September 06, 2002, 07:25 PM: Message edited by: Bizzy ]</small>
