Brake tool clarification
JohnW63
So. California
As mentioned in my previous post, I was having trouble getting the rear brake pistons to move in, with a cheap tool from Autozone. It was mentioned that Napa had a better one for about $18. I went to my local Napa and the only tool they said they had looked just the same. A cube with various prongs on it, for about $10. Do all Napa stores carry the same stuff ? What does the "good" version of the tool look like ? Any other place to get it ?
( I'll also try opening the master cylinder cover or the bleed nut to make the process easier. )
JohnW
tomw
Rochester, N.Y.
There is a different type of toolavailable which can press the piston back into the caliper as it is turned. I got mine from Mac tools. Try opening the bleeder when turning the piston-some times it is almost impossible to push brake fluid back through the porportioning valve.
Tom W
drivinhard
Gainesville, GA
Napa does (or did) carry the correct Ford rear disc/piston tool. It's not the generic cube, it's a 3/8" socket wheel with the correct spaced prongs. About $15 if I remember right.
stevetatro
Cincinnati, Ohio
Yeah...what drivinhard said. Round, only one set of prongs, perfect fit for all recent Ford rear caliper pistons.
megaplay
Cincinnati OH
Not being able to find the tool and needing to do my back brakes quickly here is why I did. Take that cheap cube thing from Autozone then cut everything off the side you need leaving a flat square with the correct prongs. Then use a c-clamp attach it to the brake with your new tool. Now two people come in handy at this point. Use a crescent wrench and turn the new block and press with the c-clamp. Takes some time though. I know it is not the easiest but it worked. Hope someone has a better idea of cheap.
nothingtoseehere
I used the cube to do my rear breaks and had no problems whatsoever...takes a little elbow grease to push down on the ratchet in order to keep it in place and you should try to move very slow having a second set of hands hold the cube in place. Got both my rear brakes done in about a half hour.
JohnW63
So. California
I found the tool !
Part Number SER3355 $16.95
It's was not with the regular tool, but on a specialty tool rack. This guy knew about it. The guy the other day said the cube was all they had.
JohnW
