nkb93
SLO 4 SHO
When cruising straight or braking, my car wants to pull off the road to the right. I don't think it's a simple alighnment issue, though, because the problem seems to correct itself under acceleration, when it seems to track pretty straight. It doesn't take much acceleration either (part throttle 5th gear will do it). I'd like to figure out what's causing this as it's pretty annoying and is probably wearing my tires out prematurely.
I checked the subframe bolts, they seem tight. I recently replaced my strut rod bushings (both the SF and LCA end bushings), which seemed to help a little but not much. The strut rod receivers on the SF felt pretty solid when I had the bushings out. Tire pressures are balanced. No significant pops or clunks (very occasional one when backing up, sounds like it's coming from the left front).
The rack and pinion has a questionable amount of play, although the tie rods seem decent. I'm thinking it may be a ball joint on the right side as that one had a torn boot for awhile. Any other ideas for things to check?? It's way overdue for an alignment, but if it's a busted joint I want to fix that before taking it in.
thanks for the help.
