repoman88tc
Greetings All, We have a 95 3.0 MTX Sho with no brakes. Found that the small box that several brake lines are pressed into on the drivers side inner fenderwell has a corrosion problem on the pressed lines going in. Luckily the line blew a hole just as my son was getting home (unknowingly). Next day he backed out and pedal fell to the floor when pressed, no brakes.
Mechanic friend says this part with pressed in lines comes as a complete assembly and has to be replaced as lines are corroded and a line splice isn`t safe. With that said, where can this part/assembly be found as Ford says they don`t carry it anymore.
Also, Car Fax says this was a Connecticut car when new and was there for 4 years before coming to Georgia. After further inspection, all brake lines to rear had been replaced previous to our buying car but not front lines.
Any help with this issue is appreciated. Thanks, Alan
