SHOracer14
Me-0 Diffs-6
Ok this is a classic example of a SHO repair. Just a simple replacement of pads and rotors and painting calipers gone awry. Ok I replaced the front pads and rotors and just the rear pads as well as painted the front calipers. I put everything back together and bled the lines. For some reason the pedal goes directly to the floor and I have no brakes! If I pump on the pedal it builds up pressure and helps me stop a little bit but not as well as it should and then the pressure relieves itself unless I constantly pump the brake. Ok there is a weird gurgling noise coming from under the hood by the master cylinder like fluid dumping into an open container. I thought maybe the master cylinder had an internal leak so I changed that out with a good used one (this my still be my problem I just don't want to pony up the dough yet). So I replace the MC, bleed at the primary and secondary lines and then bleed at all four corners. Still no change. SO I go ahead and replace the front calpers thinking maybe the pistons are bad. Replace those and bleed again. Still no change. So talking to a couple of people they think that if my rear lines are bad may cause air to have gotten into the lines. So I change the rear lines and left rear caliper (which began to leak for some reason) and again bled the lines (my E-brake is disconnected BTW) but still no change. There are no leaks in any of the lines and I am getting pressure at all four corners when I bleed them. Thinking maybe I didn't do a good enough job of bleeding the lines I bled them again in the RR,LF,LR,RF pattern and still no change. I have absolutely no leaks at any point in the braking system. Now the only other thing that comes to mind (since I've replaced damn near everything and it worked before I pulled the calipers off to paint and put pads and rotors on) is something with the ABS. I decided to see if I could make it come on by pumping up the pressure and smashing it and I can get the ABS to kick on and then the pressure in the system goes back down (pedal goes to the floor). Now I sitll have that weird noise up by the master cylinder like fluid is dripping into an empty container (only when I let off the pedal). Is there anywhere else for my to bleed? Is there a check valve that may have opened on the ABS pump? Could the ABS pump be bad or is it possible that the brand new looking master cylinder I picked up could be bum? I'm out of ideas... PLEASE HELP ME> (I've been without the SHO for a week now).
