Brake modification...
[email protected]
Albany, OR - USA
I'm looking for adapters to modify/upgrade the rear brakes.
For details, please view http://sho.kythri.net/rear_brake_upgrade/
Does anyone know about these, and know where I can get a pair (or have a pair for sale)?
1993 Ultra Red ATX
The rear brakes do so little work that there is very little to gain from upgrading them.
Scott
NJshofear
Medford NJ
True that they dont do much, but to those of us with really "open" 17 and 18 inch wheels the rears look horrible, id get em just to make the brakes look like they fit. 96 brakes all around would look awsome, but you would lose the parking brake i think ??????
Jeremy
Red 89 SHO
MODS:
-Upgraded brakes,
-17x7.5 Alesso Turbo(hyper black) wheels W/falken GRb fk451 tires (225/45/17)
-Custom bent single exhaust exiting under SHO on the back bumper
-Coilovers from IPT (when they come in)
-Pioneer head unit, with 2 Rockford Fosgate 12inch subs, and RF amp
-Two row copper radiator
Coming soon: SFC, LSD, forced induction (twin-turbo or a S/C)
AIM:Tiedie6683
AutoXSHO
Glenwood, MD USA
This has been tossed around. The rear caliper to use is the early model (pre-'93) caliper that is intended for the vented rotor. Remember the first SHOs used 10.9" vented rotors (the same rotor) front and rear. Later SHOs used a solid rotor. Anyone who has the early car just needs the proper bracket and larger rotor to do this upgrade and retain the parking brake.
Later SHOs need the brackets, the rotors AND to backdate to the early caliper. The pictures on that site show the early rear caliper with the big '96 rotor.
Bad idea unless you have a big brake kit up front like the Baers, Wilwoods, cobras, etc or are willing to reproportion the rear brake. If you do this with 11.6" front brakes you will have way too much rear bias.
John V
95 MTX
DeaconBlue
Cleveland, Ohio
John V. is right expect that the '89 SHO used the same exact 10.1" rotor front and rear. The '90-92 Gen I's used the same size 10.1" front and rear.
Anyway, the point he made is correct. Unless you have gone past the '96 11.6" front brake upgrade to either of the 12.5" Baer/PBR or the 13.0" Cobra/Baer/PBR or the one of the Wilwood kits, upgrading the rears to a 11.6" setup would be functionally fruitless. Although I would have to agree that with open design 17" or 18" wheels, the stock 10.1" rear rotors do look non-existent. Some people have also decide that they want 13" rotors front and back for looks only, to which I say to each his own.
Also any rear brake upgrade should be accompanied with a change in the rear load proportional valve setup. You need to make sure you have the proper fluid flow to the rear calipers and a balanced braking system.
For '93-99 SHO's the mod consists of '96 11.6" front rotors, stock '90-92 rear calipers, mounting brackets and pads along with a set of custom machined caliper mounting bracket adapters and hub centric ring adapters to fit the 11.6" rotors on the rear hubs. These adapters move the rear caliper about 3/4" further out from the rear axle centerline as well as center the caliper side to side with the larger rotor allowing for proper clearance and alignment.
The first person to do this mod was Glen Murdock back in Nov '99. He machined his own adapters as have many others.
95 MTX
with a few mods
sho_can
Salt Lake City, UT
Hey, I was wondering if the brackets would work on the front? I have a 92 and I get the feeling that the only way to up-grade the brakes is some $800.00 kit, can i us the bracket up front or is this a dumb question??? help
jthomas68
Area 51
It looks very familiar,whose SHO do those brakes belong to?
Jeremy Thomas
Juiced 91+
SHO Pic Of The Week:
