brake lights problem
s'good
San Diego, California
I just found out that all my brake lights are out. Checked bulbs and fuses, but no luck. Is there a typical place where the wiring is weak? Has this happened to anyone else? How did you locate the problem?
Please disregard that previous response. I meant to say the brake ON/OFF switch (BOO) switch mounted on the brake pedal. It didn't hit me until I logged off earlier.
<small>[ May 18, 2002, 09:05 AM: Message edited by: sdpatt ]</small>
SHONUT91
Cameron,Mo.
You may want to also check the brake lamp switch that is attached to a bracket behind your brake pedal.hope this helps :)
<small>[ May 18, 2002, 08:21 AM: Message edited by: SHONUT91 ]</small>
