brake light
K
kitts67
Guest
I have a 95sho with a brake light on the dash that will not go off. So far I have changed the Master cylinder cap and the e-brake seems to work properly. Anyone have the same problem or have any suggestions?
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Check the spring sensor for the e-brake. It may have gotten stuck. I had that problem and thats all it was.
92 White SHO
HiRevs Competion Clutch
SHOSHOP Engine Mounts
Koni Shocks
StrutTower Braces
UD Pullies
Awesome Sound System
K
kitts67
Guest
Thanks for the info but it did not work. I tried to disconnect the plug at the master cylinder and this time the light went out. I guess it is time to shoot the wires for a short. Any other ideas?
