Brake light at WOT
gbizzle27
Bradford, Pa
Everytime i go WOT in first or second the brake light comes on. Does anyone have any idea's here, i am lost?
LJRuddy
Pop lock n drop
Poaceae fields
Could be the force of the acceleration is causing the pedal, to touch the contact that turns on the light when the pedal is pressed. Is your brake pedal loose?
SHO#7
Cincinnati
LOUDSHO92 said:
Hows the brake fluid is it full?
I was thinking the same. The force of the car is moving the fluid around enough that the low fluid level light comes on. Hence you e-brake light.
Mike
spazmoid
RI
Sometimes my battery light comes on when i floor it. But thats different lol
gbizzle27
Bradford, Pa
Thanks guys. I will hop right on that when i go out to see if my coolent desided to stop leaking yet.
BRAKE light at WOT is due to low fluid level.
If your fluid level is low and you have no leaks, you have pads that are well worn. Inspect and replace as required.
That fluid did go somewhere - the calipers where it is compensating for the worn pads.
ManySHOs
South Jersey
While we are on this topic, has anyone had sucess repairing the switch on the parking brake pedal? My brake light is coming on as well but it's because of the switch (I can jiggle the pedal slighty to get the light to turn off and the fluid level is fine). I haven't even looked at it to see where it is or how I can get to it. It this something that I can clean or something that I replace?
Thanks
Ian
