I've been chasing a boost leak for months, at this point you can here it as soon as you get into boost. Only mods are gearhead e30 tune with stock hpfp. I also can't get over 12 psi when I should be around 16psi.
I started seeing oil droplets on my coolant reservoir right below the cap, passenger strut tower, catch can lines. After inspection of the noise maker could see oil coming out so put a plug in it. Still the same so then seen oil on the intake hose to throttle body.
Cut the plastic band clamps and put t clamps on them. Still getting oil spraying onto coolant reservoir. Replaced with mks intake pipe still getting oil spray. At this point has to be throttle body?? Does anybody have pic of the dust cap that blows of the throttle body? I don't see it and throttle body is clean but its the only thing right there that could be causing this.
