Bondurant car with dead battery again!
Off Road SHO
Moderator
Eric,
Your Bondurant car has a dead battery again. Putting it on the trickle charger tonight for 12 hours to see if it will take a charge.
Tom
BigCaney
N.E. Ky
Not sure which of the Bondurant cars you have, but 2 of the 3 Bondo SHO's I have had will **** the battery overnight if the main power disconnect is not cut off daily. :shrug:
Off Road SHO
Moderator
Mike,
Yes, I left the master switch on once and it drained the battery, but have since charged it to (what I believe is ) full charge and it won't hold it. Pulled the cover off and it's a brand new FOMOCO battery so age is not the problem (at least not with the battery :) )
I'll have to do a drain test to check for leaks.
Tom
