Bog
SHODano
Hotmail.com
My 93 Sho has a bog when you have it at about 3/4 throttle, replaced plugs wires, and y-pipe.
BeatDaSHO
Hatboro, Pennsylvania
well ur description isn't too detailed but i'm thinking maybe the O2 sensors. Did you replace these when you replaced the y-pipe? Is there any oil in your plugs wells. Check that.
Greg
fredhurderjr
www.neshospecialists.com
Dan's 93 has a noticeable bog on >2/3 throttle. It felt like a plugged cat (from previous non-SHO experience). At idle through half throttle, the car feels great. At WOT, it won't get out of it's own way. Secondaries are working fine.
He's got a new-to-him used stock Y-Pipe on the car, as well as 2 new O2's on there. The next thing I was going to look at was the TPS, then the MAF. About the only other thing I can think of is possibly clogged injectors or possibly a failing pump or fuel pressure regulator. Pump isn't screaming though.
We recently put a very nice powdercoated intake & cam covers on for him. He's got new gaskets all around & things seem pretty tight vacuum-leak wise. He says the car feels about the same as before the valve adjust, plugs & wires & intake swapout - maybe a little better.
If anybody's got suggestions, we're happy to hear them. Thanks folks!
