body shop repair prices
sho4life
midwest
anyone know how much shops charge to fix bumper support, fender headlight and headlight support. I know that they might have a hard toime finding these parts. I found a great deal on a damaged car but dont want to fix it.
figure $100/hr + parts & supplies. paint is expensive.
sho4life
midwest
they price will rise quickly as its time consuming taking the front end apart. I wouldt be surprised if a sho is considered totaled with minimal damage
Phoenix
SHOHOLIC
QC , Canada
If you cant pay for having it done you have 2 choices.
-Do it yourself to save AT LEAST the installation/labor (not the paint though), Finding the parts yourself can also reduce the price tag alot.
-Sell the car and start walking.
mosho93
Well-Known Member
Wausau, WI
I would say it all depends on the shop. I would do some calling around and comparing of prices. You will probably save money if you can come up with the parts first...
sperold
Last to Know
If you can't fix it yourself, then don't even start.
Unless you can find the body shop that your local used car dealers use, as usually they are not dialed into insurance work.
If I were doing it, I would consider getting the parts, and having them painted before they are installed. That will save you quite a few hours, at $100.00 per hour.
platoribs
Live to Drive
Plat0ribs House of SHO,il
Rebuilding the front end of an SHO isn't that complicated. Headliners can be had new for less than 50 shipped (they make then in Lombard, IL, just down the road). Then pick up a good bumper isolater and shim it bac into place, rehang the filler... now the covers aren't cheap for new, 300 IIRC and getting one painted right with the flex additives will run into 300+ so 600 painted is about as good as it gets then you hang it!
You could probably make the front end of an SHO look pretty good for $1000 in parts alone: Isolators, rust and wrinkle treatment, headliner, lights, filler, cover, etc..., with nothing for labor.
FamilySHO
Croton on Hudson, New York
If the frame is not bent you could buy used body parts of the same paint color from someone on the forum and bolt it in yourself. You can have the front end painted and blended with the rest of the car or leave as is. Otherwise, any type of serious bodywork/paint will not make sense costwise. You'd be better off buying a well maintaned, undamaged car.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
The hard part to find is the bumper cover itself... if thats not too messed up looking.. .a bumper support, and that headliner / headlights are only a few hundred from a JY or off the forum here.. then you can get a new bumper cover when someone spins a RB on a silver SHO.. give it time.. they always pop up... :)
Where in the "midwest" are you exactally? I know of a few JY's with SHOs.. I dont believe they have anything that silver color tho... but everything behind the bumper would be there...
sho4life
midwest
I found the parts for $200 . waiting till spring to get them though. I found a silver sable but its probably different color code
