blower control module hoses
SHOslamwagon
Toronto
where do they go? i currently have them capped.
my a/c is acting up, i just charged the system and it blows cold, however when i click full a/c and put the fan to full blast it blows cold for maybe 10 minutes after starting the car then suddenly blows full hot, im hoping these hoses are the solution, and i ran the eatc self test and got no errors (888)
shoon
cliTaurus
Dawson Creek, BC
If your referring to the 1 hose that comes off the module, it runs up behind the passenger side of the dash where that "SHO" emblem is (above glovebox). There is a sensor behind the sho emblem used to detect ambient air temp in the SHO.
Not sure what would cause that problem... it sounds like the EATC might be opening the blend door. Does the compressor still cycle even with the hot air blowing?
SHOslamwagon
Toronto
well i figured it had something to do with the car not knowing the internal temp, my a/c compressor stays engage even when blowing hot, i did come across a bunch of posts saying i mite have to take a shim out of my compressor, but if its still engaged i say its all good.
my blower module, has 2 hose nibs coming from it, i seen in some pictures it looks like 1 runs down and under the blower box somewhere, i will hook up the one to the sho emblem, hopefully something good happens.
