BLEND DOOR REPLACEMENT
SHO IT
ST. LOUIS, MO
I JUST GOT MY FIRST SHO AND I LOVE IT. THE ONLY THING I HAVE LEFT TO FIX IS THE DLEND DOOR. IF ANY ONE HAS ANY INFO ON EASY WAYS TO FIX OR GET TO IT I WOULD BE GREATFUL.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I knew mine was bad and it took me a while to get it in. I found out the bad news. You have to remove the entire dash to get to it. This means several hours of labor to get to it. You can check www.shotimes.com for more info on this. It would have cost me $500 :mad: to have it fixed, yeah it sucks.
projectSHO89
SHOless In St L
SHO IT
1) Hit the CAPS LOCK key. All caps is considered shouting and is rude.
2) I've done this job. While it's no fun, it is doable in less than a day. Make certain you have the BDA (assuming that is the actual problem, you did not indicate by what process you arrived at that conclusion) on hand before starting.
Steve
SHO IT
ST. LOUIS, MO
Sorry about the caps. and i found out by the self test is reading blend door. it intermitenly goos to hot on its own.
