NotSoSlowSHO
Gas is $$ WALK!
Im having trouble bleeding the LR brake on my '89. Car is sitting on the ground, and bias valve is "loose" as it should be. It is bleeding, but requires tremendous pressure to get the fluid moving. Im not so worried about getting it bled, because it is now, Im just worried about what could make the brake SO HARD to bleed?
Any ideas? Could this be a bias valve issue?
Thanks!
Thanks!
