big time oil leak
shonuffmine
wildchild
sweating balls in fla.pan
well got every thing cleaned up n got tags on the 95,took her out for a few hrs n noticed it,s leaking oil heavily on the firewall side head(#2 head?) looks like it has been doin it for awhile cause the tranny n oil pans are coated pretty thick.My question is does the valve covers loosen up with age n mileage (she has 186,000) or is there a common issue here?i did notice the oil pressure sending unit weeping and did purchase a new one .my bud buzz said his 92 did something like this n all he did was tighten the valve cover up some,suggestions please
SHObill
'The Collector'
Rochester MI-48307Detroit
with all the hot/cold cycles, the rubber VC gaskets dry out & become brittle & no longer expand & therefore leak. You can not just tighten the VC's down unless they were not torqued right to begin with,the VC bolts have a stop on them. Do you have oil in the plug wells?? It could also be the cam seals leaking too.
raff18
frosty95mtx
ontario canada
valve cover seals do go bad over time. sometimes tighting them a little works but its time u did em sounds like its time to do some 60k service
shonuffmine
wildchild
sorta tough coughing up a $125 for a gasket set, haven,t work since june!the prev owner did no reg maint except oil changes,belts n waterpump.so i have alot to do
