Black '93
Guest
I recently bought a new timing belt and installed it on my '93 ATX. The car ran fine after I got it back together, but I lost some power on the top end. I thought that I had done some damage to my motor when my belt broke, but since it's a non-interference motor I figured it was very unlikely. I thought that maybe the belt slipped when I first started the motor because of the tension being too tight so I took it back apart only to find out that my timing was advanced 10 degrees! I was wondering how the **** this happened so I took the timing belt off and installed it again. Guess what? Still at 10 degrees timing! It was the correct belt, so me and my buddy thought that maybe they put the white mark for the crankshaft 1 notch too soon. We moved the crank 1 notch ahead ( one notch past the white mark on the belt) so it was at 0 degrees timing. Fired up the motor, and now it runs fine and has all of its power back. The moral of the story is DO NOT BUY A TIMING BELT FOR YOUR SHO FROM LEE AUTO PARTS. I forgot what brand the belt was, but it cost about $40.00 ($100 Cheaper than ford) and the number that is printed on the belt is 202. I called and told the guy at lee and he was cool, but I'm not gonna take it off again just to get another belt that might be mismarked. It could just be the one belt that I bought happened to be a bad one, but be careful.
Mr.ASE.
