Best routing for oil pressure switch??
tery
Silvia survived the purge- summer car
minnesnowta
I'm guessing that this line going into to side of the bottom of the oil pan is a pressure sending switch maybe, ...anyway, the guy had it routed behind the starter and that put a lot of strain on the wire. I routed it under the starter and toward the front of the car so it is loose/free. Then just zipped it so it is secure. Is there any reason the wire for this switch is supposed to be routed behind the starter?? I hope not..
Terry
?? behind the starter and into the side of the oil pan? that is the low oil level sender. typically it is routed behind the starter so that you can r/r the starter without messing with that wire, but it doesn't really matter...
tery
minnesnowta
Thank you guys, there is no leak, I just thought the line was really taught when it was routed behind the starter, I let it be lose going under the starter and then zipped to the other wires there...rr starter??/ I don't think it'll ever need another starter ...:-00
When I moved that ps fluid cooler, it was all pretty easy all in all.
Thanks again,
T
