Best O2 sensor?
From those that run WBO2s what have you found to be the best Narrow Band O2?
:tumbleweed:
I guess I mean to ask has anyone seen any difference in the switching cycles between various brands.......
I have some NKG ones who is the OEM manufacture of the Ford ones.
But have you seen any difference in the hi/lo swings in any diffrent ones?
Phoenix
SHOHOLIC
QC , Canada
I heard once my friend (mustang guy) saying the Volks ones were the best for narrowband. I cant verify that though.
2L8V8_4sho
SHO Connoisseur
Washington DC
What difference does it make for narrowband? You're operating between 0 and 1 volt. If you're worried about accuracy, why not worry about the wideband?
I'm not worried about the accuracy so much as I am wondering if some switch faster than others.
The WB I can easily calibrate but then again I have no reference to compare it against.
You added a hyper ground to the O2 sensor?
I've got a very good ground system. The O2 grounds to the PCM anyway.
hawkeye18
Sorta cares
Norfolk, VA
if you have an electric toaster oven, you could just set it in there and crank that sucker up as high as it will go... look up what it should read for 20.9% O2 and calibrate it to that!
That may or may not actually work. I'm just brainstorming.
Well I have a WBO2 that I can calibrate and log the actual AF readings. Which reminds me the WBO2 is set for 1/6th second updates. I could make it quicker I guess and see if that correlates to the actual NBO2 voltage reading swings I am getting.
fwd2
alma arkansas
o2 sensor question
need to know if running without it being hook up, because i raced the sho on dirt?
ribeye2065
