RStalveyARFF
too many shos
transmission is the same, but 89 and 90 used a 9.25" flywheel. Most cars have been upgraded to the 9.75" either by recall or by the owner but there are still a few floating around with the 9.25" FW's.
Mike Kopstain said:Everything...The centerforce never seemed to work quite right on the SHOs especially when combined with lighter flywheels.
The Clutchmasters Stage III setup uses a dual diaphram disc which results in much more clamp load and uses a kevlar disc. It will handle anything you can throw at it and more.
Pressure plate, thanks for catching that...SHO Dude said:What's a dual diaphragm disc?
Robby, While Josh is using his disc on his car I beleive he is still using a CM DD pressure plate.
Depends on what you like and can handle. Like I said, I've never used this clutch, but some people say yes and some say no.jeanrw2000 said:Can you still use the CM St.3 for a regular go to work everyday comute type driving?![]()
By the way i just like to add that for the last four or so months i have being using MidwestSho for some upgrades and some general maintanance supplier and i am very satify with their service keep the good work![]()
SuperchargedSHOguy said:midwest SHO...
