gen3performance
alright i have been posting on one of the other threads to see if i could figure out wtf is going on with my car. i was just outside checking out my car again. i decided to swap the coils from front to back to see if i would get any different affect when i un hooked the back coils of course you cant start the car and check the back ones so i got done i also ran a ground to each valve cover from the battery making sure troughs ****** braided ground wires where doing a good enough job .started it up and took it around the block a couple times. i still had my miss though i got back and pulled back into the garage and took a look under the car. i never noticed this before witch doesn't mean it wasn't there but my cat was beat red the one on the y pipe not the 3rd one witch is punched out i have seen this before on one of my other cars. i cant remember what it was and how i fixed .it if i did fix it. any ideas. i would guess clogged cat maybe? i have been running some fuel treatments through my car just about every couple tanks . is it just because of un burned gas from my misfire burning up in the cat any ideas
when i got this car i always had this problem witch is with the peddle tot he floor it would take off and then it would fall on its face like it had no gas the bomb take off then bomb fall on its face it also seemed to me that it wasn't quit going like it should like it was holding back or something was holding it back a friend of mine suggested it was a clogged cat but i let it go and never messed with it do you think maybe now it is clogged up ??
