Battery light
Midwest
I just installed new fog lights and the work great. The only problem is after a few minutes of having them on the battery light goes on. If I turn the fog lights off the battery light goes off almost immediately. I've done a search but found nothing similar. Has anyone else had a similar problem? Electrical? Thanx for the help.
93nighthawk
Mitchell, SD
What kind of Fog lights (amps?)and how did you wire them?
Unless they are major off road fog lights that suck up a couple hundred amps, I think that your alternator might be on the way out. The stock alternator can handle a lot.
Also is this at any time or when you are at an idle? Underdrive pullies?
Midwest
I installed the same factory fog lights pulled from a '91 (I have a '90). It didn't matter the rpm's, if I turned them on, idle or driving, the bat light would come on. So, I'm driving home from work (about 7 miles) at night, and tried the new Fog lights and no battery light. WTF!?! I'll update the experiment the next couple of days.
