Battery Drain
SHOMADMAX
Speed Demond!
WA, I miss WY!!!
If i leave my car set for more than a day and a half strait without running it, the battery dies. I checked the battery, its good, its not a ground problem, its not the thing in the trunk, and it is not the alternator. What could it be?
:hail: You have never failed me SHOforum members :hail:
Ishodu
Use an amp meter with the car shut off and look for a excessive draw of current, if found you can start pulling fuses till you locate the circuit that is doing the drawing.
SolidState
No Mo SHO
Toronto, Ontario, Canada
FWIW, I had a brand new battery and altenator, and could still **** the battery very quickly.
Replacing my battery cables made the world of difference...the battery now gets all the charge it needs...
SASHO91
Zoom Zoom
San Antonio,TX
load test the battery..
im not sure if autozone can do that or not....
the battery may "looked charged" as in read 12.6V's, but have not cappacity left.
you have some parasitic draw of some kind...
SHOMADMAX
Speed Demond!
WA, I miss WY!!!
I did that already and it checks good for that and good charge.
With everything off and the key out of the ignition there should be 0.050A draw or less. Anymore and there is a problem.
