Battery drain issue...
Majestic
Anyone have any luck tracking down a battery drain issue? I have a four month old DEKA that has recently started draining overnight. I can drive it around and it will charge up fine. I reset the BLM when I replaced the battery and it was fully charged. I can leave it on the charger and it will fully charge, so I think I must have something draining it. I don't have anything in any of the outlets/hubs. Ideas?
Majestic
Well... I did a parasitic draw test and am sort of stumped. For about the first minute I had the multimeter hooked up it showed around 2 amps, which is too high. But it gradually dropped to .2 amps, which is still a bit high. I checked all of the under hood fuses and when I removed a 50 amp square fuse, the draw dropped to .01. I replaced that fuse and the draw stayed at .01 for the rest of the time I had the meter connected. Guess I need to see what that fuse controls.
