Liquid_force
I've agreed in principle to purchase a '99 locally.
I have a laundry list of repairs I will be making before I make it my DD.
I want to try to assemble a "how-to" in one location that will help me get all this accomplished.
A check list of tools/supplies/parts will eventually be included as well.
So if you can take a minute and dig up a link or provide some suggestions based on personal experience I'd really appreciate it.
I am an average home mechanic, but I have zero experience with this motor. I have been reading a lot and looking at a lot of pictures.
Step one will be cam weld prep.
I will definitely reference the cam weld procedure from v8sho. What I would like to add to that is a set of instructions for a welder. I have a welder locally who is willing to do the work, but they asked me to bring some information on exactly what is req'd.
So to those of you that do general welding, or have welded these cams, what would you want to know if you were doing these welds for the first time?
Other maintenance during cam weld tear down?
I plan to put in new plugs. Don't really know otherwise.
Step two - more of a step 1b, will be to fix a miss. Based on my reading mainly on this site I believe it's a coil. A code scan should tell me what cylinder is missing, right?
Hopefully this can be done fairly easily while it's open.
I will probably have the codes scanned the day I take possession which I believe will be Thursday.
Three - brakes.
Fronts definitely, pads/rotors. I will probably let the rears go for now as long as the pads have some wear left and the rotors aren't too thin. Any tricks to compressing the pistons? On my '88 Turbo Coupe the pistons had to be rotated while they were compressed.
Four - a/c.
It's intermittent. Sounds like it may be a shim issue. It's cold when it decides to run. I might put this on the back burner since cool weather is just around the corner. Which brings up another concern...I hope the heater works. I never checked that!
Any way to diagnose whether or not it IS the shims?
After that it will be mainly cosmetic issues. Driver's seat leather is torn (estimated repairs appx $100), clear coat is in bad shape with other minor dents/scratches (estimate appx $800). Windows need tint.
I have a decent basic set of tools. Metric sockets - 1/4" 3/8" 1/2" drive, tq wrench - 3/8" 1/2" drive.
I've read that ratcheting wrenches are handy. I'll pick up a set if they're necessary, or close to it. I'd like a 1/4" tq wrench, but those things aren't cheap.
What are the chemicals I need to soften and reuse the valve cover gaskets?
Three - brakes.
Four - a/c.
