Bad IAC?
shofun
SD
Will a bad IAC cause bad gas mileage.
I have a rough idle and sometimes a high idle like the valve is sticking. Also sometimes the idle will jump from 14-15 back and forth when I push the clutch in and when I completly stop, the idle will go up to about 1800 rpms. Any other ideas.
Rowley
Those are very high idle speeds. The oscillating idle is usually the result of a dirty/bad IAC valve, but can also be complicated by a throttle position sensor with a dead spot or fluctuating signal at idle.
Have you reset the idle program after having the battery disconected?
Scott
1991, 254K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
[This message has been edited by sdpatt (edited 01-18-2002).]
