V6Hova
I have a 95 MTX with 165000k on it. Some of you may recognize me from an earlier post about a malfuncitoning CID. Now that its all back together and running, albeit not well, I have no CEL. However it runs bad with infrequent moments of running good. Sometimes it runs so good but then shortly goes back to crap.Checked fuel pressure I get 30 psi at KOEO and 31 at idle. SO i checked the codes and came up with none, then i ran the cylinder balance test and got a 2. Upon checking the injectors with the suggested screwdriver i did notice that one injector does not tick. I don't know how to tell which cylinder this is for. How do you replace an injector? Do you have to remove the intake manifold? How much are injectors? Should I just try some injector cleaner first? Any help is greatly appreciated.
