Bad front left squeak
TicoSHO
93 in Largo, FL
Largo,FL,USA
I have a loud squeak from the left front tire. It is louder while stopped, not so much under power rolling fowards or backwards. It also gets a bad wiggle at about 60 or 65 mph. I can feel it right under my left foot. Has anyone else had this problem and could it be dangerous? I don't want to be an the way to work and lose a tire on US19 at 70 mph. That would really suck. :frown:
Thanks for any input.
ShoMotion93
Guest
Mansfield,Ma.USA
Are you turning the wheels side to side when you are stopped? If so, take a look at your outer tie rod end, I've heard 'em squeak when they get bad. Good luck with it.
TicoSHO
93 in Largo, FL
Largo,FL,USA
It only happens when I turn the wheel to the left not the right.
It sounds like a rubber on rubber or a rubber on metal noise. How much should it be to replace the rubber pieces in there? Or can a mechanically challenged person do that himself?
N3FOL
Pennsylvania
Rubber Squeek
Sounds to me that you should replace your front strut tension bushings (if you have not done this yet). My car would squeek on a forward and reverse motion even when turning and going over a small bump. I can also here it while I back-in in my driveway. So what I did was to do a lot of searching in this forum. I also found out that 'SHO Phoenix Project' website has an excellent illustration on how to replace the bushings and LCA. I replaced my Frt. strut tension bushings and decided to replace my two LCA's as well two weeks ago. Today, my front end is nice and quiet.
